[OpenLayers-Users] Problem adding a layer on top of google maps base layer
Gery .
gamejihou at hotmail.com
Fri Jun 14 06:34:41 PDT 2013
you could check these working examples:
http://jsfiddle.net/aguiguy/ZAZN8/
http://jsfiddle.net/UAxun/155/
http://jsfiddle.net/VictorVelarde/DbCgt/
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
> Date: Fri, 14 Jun 2013 05:13:56 -0700
> From: charlie at walkersworld.org
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] Problem adding a layer on top of google maps base layer
> I'm sure this is a newbie question but I can't seem to find an answer to it.
> I'm trying to add an arcgis layer that is a different projection (epsg:2277)
> on top of a base google street maps layer. I was hoping someone could take
> a look at this code and help me out.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-adding-a-layer-on-top-of-google-maps-base-layer-tp5060179.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130614/52b263e6/attachment.html>
