[OpenLayers-Users] Problem adding a layer on top of google maps base layer
cwalker67
charlie at walkersworld.org
Fri Jun 14 08:05:33 PDT 2013
Thanks Gery, but i'm still not sure I see an apples to apples example.
One of the maps in my example uses the projection "epsg:2277" and displays
some information specific to a small area in mid texas.
for the google base layer, i convert the extents from the arcgis server map
and set them in that map. This part seems to work as the google street view
shows the right area in the display.
My problem seems to be reprojecting the "epsg:2277" map on top of the google
base layer. Do you see any errors in the code I posted?
Thanks,
Charlie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-adding-a-layer-on-top-of-google-maps-base-layer-tp5060179p5060220.html
