[OpenLayers-Users] Connecting to MapGuide via WFS
Rich Bauer
rdbauer at gmail.com
Fri Jun 14 10:37:23 PDT 2013
All,
I am new to OpenLayers but have been using MapGuide for several years. I
had originally posted the below post to MapGuide list because I thought it
was a MapGuide related connection issue.
http://osgeo-org.1560.x6.nabble.com/WFS-Connection-from-OpenLayers-td5060185.html
Since then (as you can see in my update) I have found some help from the
example http://openlayers.org/dev/examples/getfeature-wfs.html. With the
help of this, I was able to make a connection (so I think). Both layers
show up in the Layers panel as it is added to the map, but the WMS layer
shows up and the created WFS does not. Now I don't know if it is MapGuide
related or OpenLayers related. Code below:
*var wmsParcels = new OpenLayers.Layer.WMS("Parcels",*
http://localhost/mapguide/mapagent/mapagent.fcgi?USERNAME=Administrator&Password=admin
* { layers: 'Samples/Sheboygan/Layers/Parcels', transparent: true },*
* { isBaseLayer: false, transitionEffect: 'resize', format:
'image/png' }*
* //{ projection: new OpenLayers.Projection('EPSG:900913') }*
*map.addLayer(wmsParcels);
*var wfsParcels = new OpenLayers.Layer.Vector("WFS Parcels", { protocol:
new OpenLayers.Protocol.WFS.fromWMSLayer(wmsParcels) });
*map.addLayers([select, wfsParcels]);*
With this there are no errors showing up in Chrome Developer tools.
As a related issue, when I use the above code, I get the error below if I
use the *OpenLayers.movile.js* script instead of the *OpenLayers.js?mobile *
script.
Error:
1. Uncaught Unsupported WFS version: 1.1.0
OpenLayers.mobile.js:515<file:///Z:/MapGuideProjects/MobileGIS/RBAC%20Mobile%20GIS/OpenLayers.mobile.js>
1. OpenLayers.Protocol.WFSOpenLayers.mobile.js:515<file:///Z:/MapGuideProjects/MobileGIS/RBAC%20Mobile%20GIS/OpenLayers.mobile.js>
2. OpenLayers.Protocol.WFS.fromWMSLayerOpenLayers.mobile.js:516<file:///Z:/MapGuideProjects/MobileGIS/RBAC%20Mobile%20GIS/OpenLayers.mobile.js>
3. initmobile-rbac.js:149<file:///Z:/MapGuideProjects/MobileGIS/RBAC%20Mobile%20GIS/Scripts/mobile-rbac.js>
4. fixContentHeightmobile-jq.js:24<file:///Z:/MapGuideProjects/MobileGIS/RBAC%20Mobile%20GIS/Scripts/mobile-jq.js>
Any thoughts?
Thanks,
Rich
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130614/74c6cb0b/attachment-0001.html>
