[OpenLayers-Users] Connecting to MapGuide via WFS
Mark Prins
mc.prins at gmail.com
Mon Jun 17 02:35:18 PDT 2013
2013/6/14 Rich Bauer <rdbauer at gmail.com>:
>.... Code below:
> var wmsParcels = new OpenLayers.Layer.WMS("Parcels",
> "http://localhost/mapguide/mapagent/mapagent.fcgi?USERNAME=Administrator&Password=admin",
> { layers: 'Samples/Sheboygan/Layers/Parcels', transparent: true },
> { isBaseLayer: false, transitionEffect: 'resize', format:
> 'image/png' }
> //{ projection: new OpenLayers.Projection('EPSG:900913') }
> map.addLayer(wmsParcels);
> var wfsParcels = new OpenLayers.Layer.Vector("WFS Parcels", { protocol: new
> OpenLayers.Protocol.WFS.fromWMSLayer(wmsParcels) });
I think (but I could well be wrong...) this was developed and tested
with Geoserver. the WMS needs to support GML getfeatureinfo responses
that exports the featuretype I'm not sure that mapguide does this.
> map.addLayers([select, wfsParcels]);
> With this there are no errors showing up in Chrome Developer tools.
> As a related issue, when I use the above code, I get the error below if I
> use the OpenLayers.movile.js script instead of the OpenLayers.js?mobile
> script.
> Error:
> Uncaught Unsupported WFS version: 1.1.0 OpenLayers.mobile.js:515
this seems clear enough, there is no WFS 1.1.0 support... when you
look at the build profile[1] you can see there is only
OpenLayers/Protocol/WFS/v1_0_0.js
You need to make your own build.
[1] https://github.com/openlayers/openlayers/blob/master/build/mobile.cfg
Disclaimer;
This message is just a reflection of what I thought at the time of
sending. The message may contain information that is not intended for
you or that you don't understand.
