[OpenLayers-Users] OpenLayers-2.12 dynamic map width with Bootstrap
Alessandro Candini
candini at meeo.it
Sun Jun 16 23:47:05 PDT 2013
I'm using an OpenLayers-2.12 map inside an HTML5 page styled with the
CSS framework Bootstrap.
Is that possible to have a dynamic map width, as demonstrated at
http://ol3js.org/ol3/master/examples/zoomslider.html, with OpenLayers
version 2.12?
If so, could you please give me an example? Thanks in advance.
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
