I've got the issue represented in this working example: http://jsfiddle.net/ZrazJ/14/ The map on the second tab get shifted, but if you resize the browser window, it moves to the correct centered position. And the first map that initially was centered, gets shifted. Any ideas on how to correct this behaviour? Thanks.
