[OpenLayers-Users] OpenLayers maps inside bootstrap tabs
Alexandre Dubé adube at mapgears.com
Tue Jun 25 05:50:58 PDT 2013
   You can correct this by calling the map updateSize method when
changing tab.  I updated your example:
   http://jsfiddle.net/ZrazJ/19/
HTH,
Alexandre
On 13-06-24 04:46 AM, Alessandro Candini wrote:
> I've got the issue represented in this working example:
> http://jsfiddle.net/ZrazJ/14/
> The map on the second tab get shifted, but if you resize the browser
> window, it moves to the correct centered position.
> And the first map that initially was centered, gets shifted.
> Any ideas on how to correct this behaviour?
> Thanks.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
