[OpenLayers-Users] OpenLayers 2.13 Chrome Problem
Andreas Hocevar
ahocevar at opengeo.org
Tue Jun 25 14:19:12 PDT 2013
I added some more commits to
https://github.com/openlayers/openlayers/pull/1019, and I'm pretty
confident that the issue is now really fixed. Brian, can you please try
again?
Thanks,
Andreas.
On Tue, Jun 25, 2013 at 5:10 PM, Brian May <bmay at mapwise.com> wrote:
> I applied the patch and I am seeing the same behavior.
> Thanks,
> Brian
> On 6/25/2013 10:20 AM, Andreas Hocevar wrote:
> Brian, can you please apply
> https://github.com/openlayers/openlayers/pull/1019 and see if it fixes
> the issue for you? For me it did the trick.
> Thanks,
> Andreas.
> On Tue, Jun 25, 2013 at 1:00 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
>> Hi,
>> I am able to reproduce the issue, but for now I do not have a clue what
>> causes it or how to fix it. I need to investigate more. So if you have any
>> additional information, please share it.
>> Stay tuned!
>> Andreas.
>> On Tue, Jun 25, 2013 at 5:35 AM, Brian May <bmay at mapwise.com> wrote:
>>> Hello,
>>> I have been testing OL 2.13 and have found a problem with Chrome on
>>> Windows. I have tested on Win7 and Vista and received the same results.
>>> Testing on IE10, IE9, and Firefox works fine. Also Mac Safari and iOS works
>>> fine. The problem is with a tilecache layer. When panning / zooming around
>>> the map, the tiles come up fine for a while, and then tiles stop appearing
>>> for a short time, then start appearing like they should again. The tiles
>>> that do not appear are blank - and stay blank. When I inspect the tile
>>> images in developer tools and hover over the missing image tile URLs in
>>> developer tools elements inspector, the properly rendered tiles displays as
>>> they should, but they have not been set on the map, i.e. the tiles on the
>>> map where they are supposed to appear are still blank. Here is the test
>>> page:
>>> http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index.html
>>> Also, sometimes, all tiles just stop loading for a bit and are pending,
>>> but then load after a long delay (like 10s), this applies to both the
>>> tilecache layer and OSM tiles.
>>> OL 2.12 works fine.
>>> http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index_ol212.html
>>> Any ideas?
>>> Brian
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> Andreas Hocevar
> Users mailing list
Andreas Hocevar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130625/27f96bf4/attachment.html>
