[OpenLayers-Users] OpenLayers 2.13 Chrome Problem
Brian May
bmay at mapwise.com
Tue Jun 25 18:19:02 PDT 2013
Works like a charm! I will leave the URL active for a few days if any
one else wants to test. Thank you for your quick response and fix!
Brian
On 6/25/2013 5:19 PM, Andreas Hocevar wrote:
> I added some more commits to
> https://github.com/openlayers/openlayers/pull/1019, and I'm pretty
> confident that the issue is now really fixed. Brian, can you please
> try again?
> Thanks,
> Andreas.
> On Tue, Jun 25, 2013 at 5:10 PM, Brian May <bmay at mapwise.com
> <mailto:bmay at mapwise.com>> wrote:
> I applied the patch and I am seeing the same behavior.
> Thanks,
> Brian
> On 6/25/2013 10:20 AM, Andreas Hocevar wrote:
>> Brian, can you please apply
>> https://github.com/openlayers/openlayers/pull/1019 and see if it
>> fixes the issue for you? For me it did the trick.
>> Thanks,
>> Andreas.
>> On Tue, Jun 25, 2013 at 1:00 PM, Andreas Hocevar
>> <ahocevar at opengeo.org <mailto:ahocevar at opengeo.org>> wrote:
>> Hi,
>> I am able to reproduce the issue, but for now I do not have a
>> clue what causes it or how to fix it. I need to investigate
>> more. So if you have any additional information, please share it.
>> Stay tuned!
>> Andreas.
>> On Tue, Jun 25, 2013 at 5:35 AM, Brian May <bmay at mapwise.com
>> Hello,
>> I have been testing OL 2.13 and have found a problem with
>> Chrome on Windows. I have tested on Win7 and Vista and
>> received the same results. Testing on IE10, IE9, and
>> Firefox works fine. Also Mac Safari and iOS works fine.
>> The problem is with a tilecache layer. When panning /
>> zooming around the map, the tiles come up fine for a
>> while, and then tiles stop appearing for a short time,
>> then start appearing like they should again. The tiles
>> that do not appear are blank - and stay blank. When I
>> inspect the tile images in developer tools and hover over
>> the missing image tile URLs in developer tools elements
>> inspector, the properly rendered tiles displays as they
>> should, but they have not been set on the map, i.e. the
>> tiles on the map where they are supposed to appear are
>> still blank. Here is the test page:
>> http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index.html
>> Also, sometimes, all tiles just stop loading for a bit
>> and are pending, but then load after a long delay (like
>> 10s), this applies to both the tilecache layer and OSM tiles.
>> OL 2.12 works fine.
>> http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index_ol212.html
>> Any ideas?
>> Brian
>> Users mailing list
>> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Andreas Hocevar
> Users mailing list
> Andreas Hocevar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130625/c2ee2488/attachment.html>
