[OpenLayers-Users] Problem Geoserver Layer
Luis Miguel Royo Perez
luis.miguel.royo at gmail.com
Sat Mar 2 02:11:47 PST 2013
Hi everyone,
I'm new with openlayers, and i'm trying to create a new map with one
layer served with Geoserver, but i'm getting some problems.
This is the code:
"//Definimos la variable map
var map;
function init() {
//Opciones
var options = {
projection: new
OpenLayers.Projection("EPGS:900913"),
units: "m"
//Creamos un nuevo objeto map en el div con el id = map
map = new OpenLayers.Map('map',options);
var mapnik = new OpenLayers.Layer.OSM();
//Añadir capa Geoserver Pruebas
var prueba = new OpenLayers.Layer.WMS(
"Test:comarca - Tiled",
"http://localhost:8080/geoserver/Test/wms",
LAYERS: 'Test:comarca',
format: 'img/png'
isBaseLayer: false,
yx : {'EPSG:900913' : false}
// Añadir la capa al mapa
map.addLayer(mapnik);
map.addLayer(prueba);
//Poner el centro del mapa en estas coordenadas.
map.setCenter(new
OpenLayers.LonLat(-412267.21675,4926706.34959),6);
//Controles
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl (new OpenLayers.Control.MousePosition ());
map.addControl( new OpenLayers.Control.ScaleLine());
But Firebug show me this error:
TypeError: a is null
http://localhost/arqueoserver3/OpenLayers-2.12/OpenLayers.js
Line 467
What I'm doing wrong? Probably is something stupid, but i can't see it.
Thanks.
Luís Miguel Royo Pérez
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130302/cd8ef234/attachment.html>
