[OpenLayers-Users] display a border at the end of the world
Sergeant_york
electronicpanda at gmail.com
Mon Mar 11 17:14:31 PDT 2013
If your problem is not being able to restrict people to draw outside of
defined borders, there is a much more easier solution by the way (inside of
drawing borders =) )
You can restrict OpenLayers.Map object's extent:
http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html
restrictedExtent {<OpenLayers.Bounds>|Array} If provided as an array, the
array should consist of four values (left, bottom, right, top).
Code can be like that:
map.setOptions({restrictedExtent: map.getMaxExtent()});
View this message in context: http://osgeo-org.1560.n6.nabble.com/display-a-border-at-the-end-of-the-world-tp5039296p5039794.html
