[OpenLayers-Users] display a border at the end of the world
杨华杰
yhjhoo at gmail.com
Tue Mar 12 00:47:47 PDT 2013
It's a solution but not perfect, user still able to draw outside of the
range.
On Tue, Mar 12, 2013 at 8:14 AM, Sergeant_york <electronicpanda at gmail.com>wrote:
> If your problem is not being able to restrict people to draw outside of
> defined borders, there is a much more easier solution by the way (inside of
> drawing borders =) )
> You can restrict OpenLayers.Map object's extent:
> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html
> restrictedExtent {<OpenLayers.Bounds>|Array} If provided as an
> array, the
> array should consist of four values (left, bottom, right, top).
> Code can be like that:
> map.setOptions({restrictedExtent: map.getMaxExtent()});
> http://osgeo-org.1560.n6.nabble.com/display-a-border-at-the-end-of-the-world-tp5039296p5039794.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130312/93a5ad62/attachment.html>
