[OpenLayers-Users] display a border at the end of the world
杨华杰
yhjhoo at gmail.com
Mon Mar 18 18:37:44 PDT 2013
Hi
Just a final conclusion.
I use the graticule to display the grid on map
http://dev.openlayers.org/releases/OpenLayers-2.12/doc/apidocs/files/OpenLayers/Control/Graticule-js.html
and restrict the display area on the map
maxExtent: new OpenLayers.Bounds(-180, -90, 180, 90),
restrictedExtent: new OpenLayers.Bounds(-180, -90, 180, 90)
So here is the final one.
map = new OpenLayers.Map( 'map', {
controls: [
graticuleCtl,
new OpenLayers.Control.PanZoom(),
new OpenLayers.Control.EditingToolbar(vlayer)
zoomOffset:14,
var nav = new OpenLayers.Control.NavigationHistory();
// parent control must be added to the map
map.addControl(nav);
map.events.register('zoomend', map, function(e){
if(map.getZoom()<3){
//map.zoomTo(3);
nav.previousTrigger();
Hope this will help others.
Regards,
Hua Jie
On Tue, Mar 12, 2013 at 3:47 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
> It's a solution but not perfect, user still able to draw outside of the
> range.
> On Tue, Mar 12, 2013 at 8:14 AM, Sergeant_york <electronicpanda at gmail.com>wrote:
>> If your problem is not being able to restrict people to draw outside of
>> defined borders, there is a much more easier solution by the way (inside
>> of
>> drawing borders =) )
>> You can restrict OpenLayers.Map object's extent:
>> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html
>> restrictedExtent {<OpenLayers.Bounds>|Array} If provided as an
>> array, the
>> array should consist of four values (left, bottom, right, top).
>> Code can be like that:
>> map.setOptions({restrictedExtent: map.getMaxExtent()});
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/display-a-border-at-the-end-of-the-world-tp5039296p5039794.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130319/2c91cdf0/attachment.html>
