[OpenLayers-Users] Pop-up auto size problem
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sat Mar 16 15:51:36 PDT 2013
Hi Albrecht,
I have looked at the function `function AddMarker()` from "osm-plugin.js"
Uses a popup class with `... "panMapIfOutOfView": false, "keepInMap": true,
...` (is a cocktail that I do not like)
So when Toronto is in the middle of the map div:
* the window should be higher than the middle of the height of map div
(minus a margin),
* the map can not move ["panMapIfOutOfView"=false],
* and the popup should be all within the map ["keepInMap"=true],
* so the text of the list popup is cut.
You really want: "panMapIfOutOfView"=false and "keepInMap"=true?
And is set `feature.data.overflow = "hidden";`
Try to remove the line `feature.data.overflow = "hidden";`,
in principle scrollbars should be displayed only if necessary, as in this
case.
Regards,
Xavier
Albrecht Lohöfener wrote
> Hi Xavier,
> Here are the pictures:
> http://www.albrechtloh.de/box/pop-up_wrong2.png
> http://www.albrechtloh.de/box/pop-up_right2.png
> You can also try it yourself here:
> http://www.aus-reisen.de/reiseroute/
> The "problem" pop-up is the pop-up near Toronto. Zoom in and out and
> click to the marker. Sometimes the size is correct and sometimes not.
> I'm using Firefox 19.0.2.
> Bye, Albrecht
> Am 16.03.2013 04:30, schrieb Xavier Mamano (jorix):
>> Hi Albrecht,
>>> Unfortunately the bottom pop-up size is sometime still not OK.
>> Auto size is a very complex subject, HTML CSS... I must debug the code
>> see
>> the html generated and CSS applied.
>> What browser have you tried?
>> The text is clipped as here yet?
>> http://www.albrechtloh.de/box/pop-up_wrong.png ...
>> or now the problem is that there is little bottom margin? ... if so I
>> think
>> it can be easy to find.
>> ...show me a picture.
>> Regards,
>> Xavier
> Users mailing list
> Users at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
View this message in context: http://osgeo-org.1560.n6.nabble.com/Pop-up-auto-size-problem-tp5040499p5040899.html
