[OpenLayers-Users] Pop-up auto size problem
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sun Mar 17 02:54:01 PDT 2013
typo:
* the window should be higher ...
must be
* the popup should be higher ...
Xavier Mamano (jorix) wrote
> Hi Albrecht,
> I have looked at the function `function AddMarker()` from "osm-plugin.js"
> Uses a popup class with `... "panMapIfOutOfView": false, "keepInMap":
> true, ...` (is a cocktail that I do not like)
> So when Toronto is in the middle of the map div:
> * the window should be higher than the middle of the height of map div
> (minus a margin),
> * the map can not move ["panMapIfOutOfView"=false],
> * and the popup should be all within the map ["keepInMap"=true],
> * so the text of the list popup is cut.
> You really want: "panMapIfOutOfView"=false and "keepInMap"=true?
> And is set `feature.data.overflow = "hidden";`
> Try to remove the line `feature.data.overflow = "hidden";`,
> in principle scrollbars should be displayed only if necessary, as in this
> case.
> Regards,
> Xavier
View this message in context: http://osgeo-org.1560.n6.nabble.com/Pop-up-auto-size-problem-tp5040499p5040925.html
