[OpenLayers-Users] Pop-up auto size problem
Albrecht Lohöfener
albrechtloh at gmx.de
Tue Mar 19 19:04:08 PDT 2013
Hi Xavier,
Thank you very much for your tips. Now I'm using the settings that your
mentioned and I don't have the auto size problem.
feature.popupClass = OpenLayers.Class(OpenLayers.Popup.FramedCloud,
"autoSize": true,
"panMapIfOutOfView": false,
"keepInMap": false,
"contentDisplayClass": "olPopupContent",
Unfortunately there is a new problem: When the vertical scroll bar is
showed than the class "olPopupContent" is inside the scroll bar area.
But I'm using this class for the edge padding. Now the pop-ups with the
scroll bar doesn't look nice because the space between the content and
the pop-up edge is too small. Do you know how to increase this padding?
Bye, Albrecht
Am 17.03.2013 05:54, schrieb Xavier Mamano (jorix):
> typo:
> * the window should be higher ...
> must be
> * the popup should be higher ...
> Xavier Mamano (jorix) wrote
>> Hi Albrecht,
>> I have looked at the function `function AddMarker()` from "osm-plugin.js"
>> Uses a popup class with `... "panMapIfOutOfView": false, "keepInMap":
>> true, ...` (is a cocktail that I do not like)
>> So when Toronto is in the middle of the map div:
>> * the window should be higher than the middle of the height of map div
>> (minus a margin),
>> * the map can not move ["panMapIfOutOfView"=false],
>> * and the popup should be all within the map ["keepInMap"=true],
>> * so the text of the list popup is cut.
>> You really want: "panMapIfOutOfView"=false and "keepInMap"=true?
>> And is set `feature.data.overflow = "hidden";`
>> Try to remove the line `feature.data.overflow = "hidden";`,
>> in principle scrollbars should be displayed only if necessary, as in this
>> case.
>> Regards,
>> Xavier
