[OpenLayers-Users] Pop-up auto size problem
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Wed Mar 20 15:21:21 PDT 2013
Hi Albrecht,
I've looked a bit, I understand. But I should do tests (the padding exists
but at the end of the scroll bar, this is correct)
I'll keep thinking about this, could be difficult.
Regards,
Xavier
Albrecht Lohöfener wrote
> Hi Xavier,
> Thank you very much for your tips. Now I'm using the settings that your
> mentioned and I don't have the auto size problem.
> feature.popupClass = OpenLayers.Class(OpenLayers.Popup.FramedCloud,
> "autoSize": true,
> "panMapIfOutOfView": false,
> "keepInMap": false,
> "contentDisplayClass": "olPopupContent",
> Unfortunately there is a new problem: When the vertical scroll bar is
> showed than the class "olPopupContent" is inside the scroll bar area.
> But I'm using this class for the edge padding. Now the pop-ups with the
> scroll bar doesn't look nice because the space between the content and
> the pop-up edge is too small. Do you know how to increase this padding?
> Bye, Albrecht
> Am 17.03.2013 05:54, schrieb Xavier Mamano (jorix):
>> typo:
>> * the window should be higher ...
>> must be
>> * the popup should be higher ...
>> Xavier Mamano (jorix) wrote
>>> Hi Albrecht,
>>> I have looked at the function `function AddMarker()` from
>>> "osm-plugin.js"
>>> Uses a popup class with `... "panMapIfOutOfView": false, "keepInMap":
>>> true, ...` (is a cocktail that I do not like)
>>> So when Toronto is in the middle of the map div:
>>> * the window should be higher than the middle of the height of map div
>>> (minus a margin),
>>> * the map can not move ["panMapIfOutOfView"=false],
>>> * and the popup should be all within the map ["keepInMap"=true],
>>> * so the text of the list popup is cut.
>>> You really want: "panMapIfOutOfView"=false and "keepInMap"=true?
>>> And is set `feature.data.overflow = "hidden";`
>>> Try to remove the line `feature.data.overflow = "hidden";`,
>>> in principle scrollbars should be displayed only if necessary, as in
>>> this
>>> case.
>>> Regards,
>>> Xavier
> Users mailing list
> Users at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
View this message in context: http://osgeo-org.1560.n6.nabble.com/Pop-up-auto-size-problem-tp5040499p5041937.html
