[OpenLayers-Users] How to read OpenLayers Layer Definitions from file?
Carlo Di Michele bwt at buildware.com
Wed Mar 20 00:46:56 PDT 2013
First of all congratulation Phil :-)))
my name is Carlo (a "super nerd" of Open Layers :-(((((( ) I have to tell
you that your project is amazing and it is exactly what I wish to do.
Currently I'm working inside a petroleum company as consultant and (before
my contracts end :-(( ) I had in my mind to introduce to my bosses (for my
contract renewal ;-) ) a web solution exactly like this: BRAVO :-)))
I have a question: we have some raster maps here to overlay on standard
maps (google, satellite etc) and I would like to add also an opacity
control to see the overlap between maps. I suppose that I should have it in
a server in some way but I should tile and publish. Do you have any
suggestions on how to do it? Is it possible?
I wait with anxious your precious suggestions to the Peter's questions too.
Congratulation!!! Great Job :-)))))
Carlo
2013/3/19 Phil Scadden <p.scadden at gns.cri.nz>
> I do this. I have my layer definitions and behaviours in an external file,
> stored as json format. The application fetches the json, and then processes
> it to create the map with all the layers and desired behaviour. I have a
> web application for defining the layers and behaviours desired and storing
> to a json file. (Warning  - a non-trivial amount of work).  You can see a
> resulting map at http://data.gns.cri.nz/pbe/ (free registration
> required). The menu contents are also completely defined by a json file. If
> you look at the "interactive maps", you will see from URL, that it just
> loads different json files for each map. This gives me one set of code to
> create multiple web mapping applications. The other advantage is that each
> content and behaviour can have user groups associated with it. This way
> different classes of users (eg internal versus external versus paying
> clients) get to see different things from the same config. The json is
> filtered by user before passing it to OL.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
> ______________________________**_________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130320/6a7a0eb0/attachment.html>
