[OpenLayers-Users] [OpenLayers-Dev] OpenLayer Map restrict panning and zooming
Phil Scadden
p.scadden at gns.cri.nz
Mon Mar 25 13:27:50 PDT 2013
Resolutions array is the safest option. You can also manipulate through
minResolution/maxResolution or minScale/maxScale. (Which in the end
populate a resolutions array).
> Just a quick request for further clarification though. I understand
> that maxExtent should not be set in an event. I was mostly just
> trying to do some debugging to figure out what was going on as the
> extents were being changed, so that I could prove to myself that the
> extent was being accepted as maxRestrictedExtent (and eventually I
> threw maxExtent in there through desperation). I plan on setting
> whatever needs to be set in an onClick function for the button the
> user clicks on accepting a particular area of the map.
> But setting maxRestrictedExtent definitely works for panning, and
> doesn't help with restricting outward zooming. Do you feel that
> adding a resolutions array would be my only other option?
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
