[OpenLayers-Users] can it possible for WMS Layer (image) as Single Tile
Gery .
gamejihou at hotmail.com
Tue May 14 04:28:19 PDT 2013
Hello Mahavir,
what do you mean with "accurate lat/lon"? which problems do you have with the lon/lat values you are getting? to get a unique tile (ie. load the whole image at once), you have to add SingleTile: true in the WMS layer.
Cheers,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
Date: Tue, 14 May 2013 16:53:01 +0530
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] can it possible for WMS Layer (image) as Single Tile
Hi
i would like to get accurate lat/lon info when i zooming my base layer. i set zoom level 3 does not works but it is set to 1 then works good.
but image split into tile when i zooming it.
i m using base layer image as WMS Layer "../img/test.jpg"
how to add control zoom with right way.
with regardsMahavir
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130514/8555946d/attachment.html>
