[OpenLayers-Users] can it possible for WMS Layer (image) as Single Tile
Mahavir Trivedi
mahavir.trivedi at gmail.com
Tue May 14 22:34:13 PDT 2013
Hello
but how can i get zooming facility with single tile image .
with thanks & Regards
Mahavir
On Tue, May 14, 2013 at 4:58 PM, Gery . <gamejihou at hotmail.com> wrote:
> Hello Mahavir,
> what do you mean with "accurate lat/lon"? which problems do you have with
> the lon/lat values you are getting? to get a unique tile (ie. load the whole
> image at once), you have to add SingleTile: true in the WMS layer.
> Cheers,
> Gery
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si
> NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
> Sie es NICHT, wenn es NICHT notwendig ist.
> Date: Tue, 14 May 2013 16:53:01 +0530
> From: mahavir.trivedi at gmail.com
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] can it possible for WMS Layer (image) as
> Single Tile
> Hi
> i would like to get accurate lat/lon info when i zooming my base layer.
> i set zoom level 3 does not works but it is set to 1 then works good.
> but image split into tile when i zooming it.
> i m using base layer image as WMS Layer "../img/test.jpg"
> how to add control zoom with right way.
> with regards
> Mahavir
> _______________________________________________ Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130515/8949ce3b/attachment.html>
