[OpenLayers-Users] Receive coordinates of the line (feature) after change in EPSG:4326 projection
Phil Scadden p.scadden at gns.cri.nz
Tue May 14 14:27:15 PDT 2013
On 15/05/2013 3:18 a.m., adidas wrote:
> Hi. How to get the coordinates of the line (in the projection EPSG:
> 4326) after a user has changed the line?
> Thanks.
> _
Without context, it is hard to be precise but in general, you would
iterate through the points in feautre.geometry and if necessary use the
transform method to convert from map projection back to lat/lon
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
