[OpenLayers-Users] geosjon format with epsg other than 4326
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Oct 11 13:03:12 PDT 2013
Thanks Julien
I just had a look at the read function of format.geojson and crs is not
read.
this.externalProjection  has to be defined in the format.
There is
if (this.internalProjection && this.externalProjection && !collection) {
            geometry.transform(this.externalProjection,
                               this.internalProjection);
My idea is to set the externalProjection by a function
var geojson_format = new OpenLayers.Format.GeoJSON({
        'internalProjection': map.getProjectionObject(),
        'externalProjection': getGeojsonProjection(request.responseText)
function getGeojsonProjection( geojson )
        //parse the json for CRS code and create the projection, if no CRS
return 4326
        //Example: return new OpenLayers.Projection("EPSG:32198");
That will work if all the features are ine the same projection.
Perhaps someone as a better idea?
many thanks
steve
Julien-Samuel Lacroix <jlacroix at mapgears.com>@lists.osgeo.org
Envoyé par : openlayers-users-bounces at lists.osgeo.org
2013-10-11 15:41
A
openlayers-users at lists.osgeo.org
cc
Objet
Re: [OpenLayers-Users] geosjon format with epsg other than 4326
Others may be able to give you more info on this one, but...
If I recall correctly there was a long discussion on the GeoJSON
mailing-list [1] on the usability of this CRS tag. I think that the
conclusion was to remove it from GeoJSON, other may correct me if I'm
wrong. So don't plan on it. Are you in control of this data and service?
maybe it could return you a WFS. Or maybe a GetCapabilities to the data
server would tell you the projection before you receive the GeoJSON.
This is a tricky one, I agree.
[1]
http://lists.geojson.org/pipermail/geojson-geojson.org/2013-May/thread.html
Julien
On 13-10-11 11:09 AM, Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> Sometimes I receive geojson from a wps service in different projection
> than 4326. I manage it like this for example
> geojson_format = new OpenLayers.Format.GeoJSON({'internalProjection':
> map.getProjectionObject(),'externalProjection': new
> OpenLayers.Projection("EPSG:32198")});
> It works but 32198 is hardcoded, and I don't know when the epsg will be
> different.
> I read that if different than 4326, the geojson should have a crs tag as
> defined here
> http://geojson.org/geojson-spec.html#named-crs
> Someone has defined a new OpenLayers.Format.GeoJSON that can read this
> tag and set the externalProjection code?
> thanks
> steve
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Mapgears
http://www.mapgears.com/
Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20131011/c181668c/attachment.html>
