[OpenLayers-Users] overviewmap and wmts servers only loading a single tile
Dave Potts
dave.potts at pinan.co.uk
Thu Oct 31 06:34:00 PDT 2013
I am trying to use a overViewMap control on a map base map thats
supplied from a wmts source
My source code is
var options = {
controls: [],
eventListeners:{
"zoomend":mapEvent
maxExtent: bounds,
resolutions: [3440.64, 1720.32, 860.16, 430.08,
215.04, 107.52, 53.76,
26.88, 13.44, 6.72, 3.36,
1.68, 0.84, 0.42, 0.21],
projection: PinkRConstants.SRS,
numZoomLevels: 15,
units: 'm'
map = new OpenLayers.Map('map', options);
var overOptions = {
maximizeTitle: 'Show the overview map',
minimizeTitle: 'Hide the overview map',
maximized:true,
size:new OpenLayers.Size(100,100),
maxRatio:300,
map.addControl(overview);
I only seem to get a fragment of the basemap in the overview map, by
setting the size options on the overviewmap to something hugh, it seems
that the overview map only ever loads a single tile. I have disabling
all the layers on the overmap, just in case one of the layers was
causing an issue, that did'nt fix anything.
So does anybody know if the overview map works with a wmts base map?
Dave.
