[OpenLayers-Users] Pinch-Zoom / Drag while having an active clickControl
floebig
frederick.loebig at live.de
Wed Apr 16 04:47:58 PDT 2014
Alright, thanks for the hint to use a listener instead.
I have added this to the init() function:
// Create Event Listener
var layerListeners = {
featureclick: function(e) {
//log(e.object.name + " says: " + e.feature.id + " clicked.");
alert("DEBUG: clicked");
return false;
nofeatureclick: function(e) {
//log(e.object.name + " says: No feature clicked.");
alert("DEBUG: no f clicked");
// Create Layer
pointLayer = new OpenLayers.Layer.Vector("Wasserhäuschen", {
strategies: [new OpenLayers.Strategy.Fixed()],
eventListeners: layerListeners
attribution:"© 2014 - Linie 11 W.l.W. e.V.
<http://www.linie11.org> ",
protocol: new OpenLayers.Protocol.HTTP({
url: "./geoData/data.xml.gml",
format: new OpenLayers.Format.GML()
styleMap: new OpenLayers.StyleMap({'default':defaultStyle,
'select':selectStyle,
'temporary':tempStyle
context: {
label: function(feature) {
// clustered features count or blank if feature is not a
cluster
return feature.cluster ? feature.cluster.length : "";
// Create Map
map = new OpenLayers.Map('map', {
layers: [layer, pointLayer, vector],
controls: [
new OpenLayers.Control.TouchNavigation({
dragPanOptions: {
enableKinetic: true
new OpenLayers.Control.Zoom()
zoom: 10,
center: [-1081125, 6212801]
I have also quoted out the activation of the previous selectFeature(). But:
It does not seem to work. For debugging reasons it should pop up an alert
windows, but nothing seems to happen. The only message I receive in the
Javascript console is:
event.returnValue is deprecated. Please use the standard
event.preventDefault() instead. >> OpenLayers.mobile.js:64
Fyi, I am using ./OpenLayers-2.13.1/OpenLayers.mobile.js.
What am I missing?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pinch-Zoom-Drag-while-having-an-active-clickControl-tp5134932p5135363.html
