[OpenLayers-Users] Adding multiple WMS layers in OpenLayers
Zach Seaman
znseaman at gmail.com
Mon Aug 18 12:00:15 PDT 2014
OL is initialized. I'm adding them via .addLayer([agregadas]). It's very
odd to me why it would work in the console but not on the page load.
This function creates the layers:
function crear( n ){
$.getJSON('json/capas.json', function(data) {
console.log(data);
for (var i=0; i < n.length; i++) {
capaObjetos[i] = new OpenLayers.Layer.WMS(
data[0][i]["id"],
data[0][i]["url"],
"layers": data[0][i]["layers"],
transparent: true,
format:"image/png",
CQL_FILTER: queryCQL(i),
projection: map.projection,
displayOutsideMaxExtent: false
singleTile: true,
ratio: 1,
buffer: 0,
visibility: false
// console.log(capaObjetos[i]);
for (var key in capaObjetos) {
var value = capaObjetos[key];
agregadas.push(value);
agregadas = [ ];
// Variables de Capas para capaObjectos
var crasicaule, microfilo, rosetofilo, submontano, perennifolia,
caducifolia, encino, pino, mezquite, tascate, mesofilo, oyamel, inducidos,
halofilo,
natural, cultivados, gipsofilo, riego, temporal, mezquital, tular,
sinvegetacion, asentamientos, carretera;
var capaObjetos = {
"0": crasicaule,
"1": microfilo,
"2": rosetofilo,
"3": submontano,
"4": perennifolia,
"5": caducifolia,
"6": encino,
"7": pino,
"8": mezquite,
"9": tascate,
"10": mesofilo,
"11": oyamel,
"12": inducidos,
"13": halofilo,
"14": natural,
"15": cultivados,
"16": gipsofilo,
"17": riego,
"18": temporal,
"19": mezquital,
"20": tular,
"21": sinvegetacion,
"22": asentamientos,
"23": carretera
$(document).ready(function () {
capaBase();
TreeMenu();
// ======= AGREGAR CAPAS DE 'USO DEL SUELO' AL MAPA ===========
map.addLayers(agregadas);
Thanks
On Mon, Aug 18, 2014 at 11:30 AM, TDS <tds at tds-net.de> wrote:
> Hello Zach,
> please give us an example of your code. Is OL already initialized? Do you
> add the layers with brackets (array) => .addLayers([layer1, layer2]) ? Only
> .addLayer() is without brackets.
> Bye, TDS
> mailto:tds at tds-net.de <tds at tds-net.de>
> 1+1=10
> You have a question? - 42 or RTFM.
> Am 18.08.2014 um 18:07 schrieb Zach Seaman:
> I have an array of layers that I am passing to map.addLayers(). When I
> pass the array to the function in $(document).ready(function (){}), it
> doesn't add them to the map (i.e. map.layers does not have any of the new
> layers added. But if I open up the JavaScript console and run the function,
> it works and my added layers appear.
> I've tried adding them individually in a for loop but that also doesn't
> work either.
> Any ideas?
> Zach
> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140818/4b1795e7/attachment-0001.html>
