[OpenLayers-Users] Adding multiple WMS layers in OpenLayers
Zach Seaman
znseaman at gmail.com
Mon Aug 18 12:02:04 PDT 2014
Upon further review, it works only if my JSON is local and not separated
from my code.
This works:
function crear( n ){
console.log("crear capa: " + n);
for (var i=0; i < n.length; i++) {
capaObjetos[i] = new OpenLayers.Layer.WMS(
capas[0][i]["id"],
capas[0][i]["url"],
"layers": capas[0][i]["layers"],
transparent: true,
format:"image/png",
CQL_FILTER: queryCQL(i),
projection: map.projection,
displayOutsideMaxExtent: false
singleTile: true,
ratio: 1,
buffer: 0,
visibility: false
console.log(capaObjetos[i]);
// push capas de 'USO DEL SUELO Y VEGETACION' a una arregla,
agregadas
for(var key in capaObjetos) {
var value = capaObjetos[key];
agregadas.push(value);
While this doesn't:
console.log("crear function");
alert(n);
// agregadas = [];
console.log("getting JSON..");
$.getJSON('json/capas.json', function(data) {
console.log(data);
data[0][i]["id"],
data[0][i]["url"],
"layers": data[0][i]["layers"],
transparent: true,
format:"image/png",
singleTile: true,
ratio: 1,
buffer: 0,
visibility: false
// console.log(capaObjetos[i]);
for (var key in capaObjetos) {
On Mon, Aug 18, 2014 at 11:42 AM, Zach Seaman <znseaman at gmail.com> wrote:
> OL is initialized. I'm adding them via .addLayer([agregadas]). It's very
> odd to me why it would work in the console but not on the page load.
> This function creates the layers:
> console.log(data);
> data[0][i]["id"],
> data[0][i]["url"],
> transparent: true,
> format:"image/png",
> singleTile: true,
> ratio: 1,
> buffer: 0,
> visibility: false
> agregadas = [ ];
> // Variables de Capas para capaObjectos
> var crasicaule, microfilo, rosetofilo, submontano, perennifolia,
> caducifolia, encino, pino, mezquite, tascate, mesofilo, oyamel, inducidos,
> halofilo,
> natural, cultivados, gipsofilo, riego, temporal, mezquital, tular,
> sinvegetacion, asentamientos, carretera;
> var capaObjetos = {
> "0": crasicaule,
> "1": microfilo,
> "2": rosetofilo,
> "3": submontano,
> "4": perennifolia,
> "5": caducifolia,
> "6": encino,
> "7": pino,
> "8": mezquite,
> "9": tascate,
> "10": mesofilo,
> "11": oyamel,
> "12": inducidos,
> "13": halofilo,
> "14": natural,
> "15": cultivados,
> "16": gipsofilo,
> "17": riego,
> "18": temporal,
> "19": mezquital,
> "20": tular,
> "21": sinvegetacion,
> "22": asentamientos,
> "23": carretera
> $(document).ready(function () {
> capaBase();
> TreeMenu();
> // ======= AGREGAR CAPAS DE 'USO DEL SUELO' AL MAPA ===========
> map.addLayers(agregadas);
> Thanks
> On Mon, Aug 18, 2014 at 11:30 AM, TDS <tds at tds-net.de> wrote:
>> Hello Zach,
>> please give us an example of your code. Is OL already initialized? Do you
>> add the layers with brackets (array) => .addLayers([layer1, layer2]) ? Only
>> .addLayer() is without brackets.
>> Bye, TDS
>> mailto:tds at tds-net.de <tds at tds-net.de>
>> 1+1=10
>> You have a question? - 42 or RTFM.
>> Am 18.08.2014 um 18:07 schrieb Zach Seaman:
>> I have an array of layers that I am passing to map.addLayers(). When I
>> pass the array to the function in $(document).ready(function (){}), it
>> doesn't add them to the map (i.e. map.layers does not have any of the
>> new layers added. But if I open up the JavaScript console and run the
>> function, it works and my added layers appear.
>> I've tried adding them individually in a for loop but that also doesn't
>> work either.
>> Any ideas?
>> Zach
>> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140818/3b2356ef/attachment.html>
