[OpenLayers-Users] Error when parsing array with OpenLayers and Protocol.HTTP()
Ezequiel Gonzalez Rial
gonrial at gmail.com
Fri Aug 22 11:47:58 PDT 2014
If you are generating this information, check this part:
> "origin": "2013P00109",
> "type": "LJ",
> *"naf": "5610A",*
the final comma in the naf line shouldn't be there.
Regards,
Ezequiel
2014-08-22 15:35 GMT-03:00 harko33 <xhanrot at gmail.com>:
> I'm trying to send a JSON file to my Node.js app via Protocol.HTTP. The
> file
> is correctly sent, but I can't access to an array. Here is the relevant
> code
> Client side
> var vectorProtocol = new OpenLayers.Protocol.HTTP({
> url: '/getcoords',
> format: vectorFormat,
> readWithPOST: true,
> params: {
> "code_company": "8501",
> "data_company": [
> "type": "LJ",
> "naf": "5610A",
> "origin": "2013P00110",
> "type": "FJ",
> "naf": "5481"
> Server side, I try to build an array with only the "origin" field of my
> array "data_company":
> function getCoords(params, callback) {
> var arrOrigin = params.data_company.map(function(d) {
> return d.origin;
> And I get this error :
> > TypeError: Object [object Object] has no method "map"
> It seems that my "data_company" is not recognized as an array but as an
> object. I tried to JSON.parse(params) before but I get another error :
> > SyntaxError: Unexpected token o
> Anyway, I'm stuck. Do you have any clue to help me to solve this ?
> Thanks
> http://osgeo-org.1560.x6.nabble.com/Error-when-parsing-array-with-OpenLayers-and-Protocol-HTTP-tp5157904.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140822/9bab61cd/attachment.html>
