[OpenLayers-Users] WPSExecute with a WFS reference using filter
Alexandre Dubé
adube at mapgears.com
Wed Aug 27 08:22:30 PDT 2014
Hi list,
I found the answer in the tests for the WPSExecute format:
https://github.com/openlayers/openlayers/blob/master/tests/Format/WPSExecute.html#L519.
So "Yes", the WPSExecute does support wfs query references that with
filters.
Here's what I added to make it work, data being an instance of
OpenLayers.Protocol.WFS.v1 :
if (data.defaultFilter) {
input.reference.body.wfs.filter = data.defaultFilter;
On the app side, here's how I use the WPSProcess object:
wpsProcessBoundary.execute({
inputs: {
'InputPolygon': wfsProtocol
output: "Result",
success: function(outputs) {
console.log(outputs);
So everything's working fine for me now. Still, I'd be happy to hear
about my approach, that being sending a wfs protocol as input data and
using its inner defaultFilter property as the way to know if the
protocol is using a filter or not. Comments would be welcome.
Thanks,
Alexandre
On 14-08-27 10:08 AM, Alexandre Dubé wrote:
> Hi list,
> I would like to know if the WPSExecute format support references to
> a WFS query with a filter, something like the attached file (I
> manually created). I'm using the WPSClient object, which is simple to
> use, and I'm currently overriding the WPSProcess 'setInputData' method
> in order to support having a OpenLayers.Protocol.WFS.v1 object defined
> as the 'data' parameter value, which sets the input.reference
> accordingly as such:
> input.reference = {
> mimeType: "text/xml; subtype=wfs-collection/1.0",
> href: data.url,
> method: "POST",
> body: {
> wfs: {
> version: "1.0.0",
> outputFormat: "GML2",
> featureType: data.featureType
> if (data instanceof OpenLayers.Protocol.WFS.v1_1_0) {
> input.reference.mimeType = "text/xml;
> subtype=wfs-collection/1.1";
> input.reference.body.wfs.version = "1.1.0";
> The above produces the <wfs:GetFeature> with a single <wfs:Query>
> node. What I need to figure out is how use the filters that are set
> in the protocol to produce the <ogc:Filter> to add to the query node.
> Does OpenLayers support that ? Any hint ?
> I'm using OpenLayers latest version from GitHub.
> Thanks,
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
T: +1 418-696-5056 #203
http://www.mapgears.com/
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140827/b1b37cfc/attachment.html>
