[OpenLayers-Users] Finding number of points in current Control.DrawFeature to allow undo() or cancel() to be called
Robert Sanson
Robert.Sanson at asurequality.com
Wed May 21 16:27:23 PDT 2014
I am trying to create a button that allows a user to undo or cancel a current sketch using a DrawFeature control with OpenLayers.Handler.Path and OpenLayers.Handler.Polygon
If there are >= 2 points, then the button should call control.undo(), but if only 1 point, then it should call control.cancel()
Here is some code for setting up a polygon layer epolys:
dpoly: new OpenLayers.Control.DrawFeature(epolys,OpenLayers.Handler.Polygon,{id: 'ctrldraw'})
here is one for a line layer elines:
dline: new OpenLayers.Control.DrawFeature(elines,OpenLayers.Handler.Path,{id: 'ctrldraw'})
Here is my undo code:
function undoFunc() {
//undo when digitising new features
var drawctrls = map.getControlsBy("id", "ctrldraw");
for (var i = 0; i < drawctrls.length; i++){
ctrl = drawctrls[i];
if (ctrl.active) {
ctrl.undo();
At the moment it just calls undo() but can't completely cancel().
Thanks,
Robert
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
