[OpenLayers-Users] (no subject)
kamarajugadda manjula
kamarajugaddamanjula at gmail.com
Thu May 22 01:15:45 PDT 2014
//OpenLayers.ProxyHost = "proxy.cgi?url=";
OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
var wps = "http://localhost:8080/geoserver/wps",
capabilities, // the capabilities, read by Format.WPSCapabilities::read
process; // the process description from Format.WPSDescribeProcess::read
// get some capabilities
getCapabilities();
// create the UI
var layer = new OpenLayers.Layer.Vector("Scratchpad");
var toolbar = new OpenLayers.Control.EditingToolbar(layer);
toolbar.addControls([new OpenLayers.Control.ModifyFeature(layer, {
title: "Select feature"
var map = new OpenLayers.Map('map', {
controls: [
toolbar,
new OpenLayers.Control.ZoomPanel(),
new OpenLayers.Control.PanPanel()
layers: [
new OpenLayers.Layer.WMS(
"OSM", "http://maps.opengeo.org/geowebcache/service/wms",
{layers: "openstreetmap", format: "image/png"}
), layer
map.zoomToMaxExtent();
// add behavior to html elements
document.getElementById("processes").onchange = describeProcess;
// using OpenLayers.Format.WPSCapabilities to read the capabilities
function getCapabilities() {
OpenLayers.Request.GET({
url: wps,
params: {
"SERVICE": "WPS",
"REQUEST": "GetCapabilities"
success: function(response){
capabilities = new OpenLayers.Format.WPSCapabilities().read(
response.responseText
var dropdown = document.getElementById("processes");
var offerings = capabilities.processOfferings, option;
// populate the dropdown
for (var p in offerings) {
option = document.createElement("option");
option.innerHTML = offerings[p].identifier;
option.value = p;
dropdown.appendChild(option);
// using OpenLayers.Format.WPSDescribeProcess to get information about a
// process
function describeProcess() {
var selection = this.options[this.selectedIndex].value;
url: wps,
params: {
"SERVICE": "WPS",
"REQUEST": "DescribeProcess",
"VERSION": capabilities.version,
"IDENTIFIER": selection
success: function(response) {
process = new OpenLayers.Format.WPSDescribeProcess().read(
).processDescriptions[selection];
buildForm();
// dynamically create a form from the process description
function buildForm() {
document.getElementById("abstract").innerHTML = process["abstract"];
document.getElementById("input").innerHTML = "<h3>Input:</h3>";
document.getElementById("output").innerHTML = "";
var inputs = process.dataInputs, supported = true,
sld = "text/xml; subtype=sld/1.0.0",
input;
//var change=inputs.innerHTML.toFixed(2);
for (var i=0,ii=inputs.length; i<ii; ++i) {
alert("Hello! I am an alert box!!");
input = inputs[i];
if (input.complexData) {
//alert("Hello! I am an alert box in complexdata !!");
var formats = input.complexData.supported.formats;
if (formats["application/wkt"]) {
//alert("Hello! I am an alert box in app/wkt!!");
addWKTInput(input);
} else if (formats["text/xml; subtype=wfs-collection/1.0"]) {
//alert("Hello! I am an alert box in text/xml!!");
addWFSCollectionInput(input);
} else if (formats["image/tiff"]) {
// addRasterInput(input);
//alert(truncator(5.1231231, 1));
//alert("Hello! I am an alert box in image/tiff!!");
addRasterInput(truncator(input,2));
} else if (formats[sld]) {
//alert("Hello! I am an alert box in formatssld!!");
addXMLInput(input, sld);
} else {
supported = false;
} else if (input.boundingBoxData) {
alert("Hello! I am an alert box in bounding box!!");
// var change=input.innerHTML.toFixed(2);
addBoundingBoxInput(input);
} else if (input.literalData) {
//alert("Hello! I am an alert box in literal box!!");
addLiteralInput(input);
} else {
supported = false;
if (input.minOccurs > 0) {
//alert("Hello! I am an alert box in minoccurs box!!");
document.getElementById("input").appendChild(document.createTextNode("* "));
if (supported) {
var executeButton = document.createElement("button");
executeButton.innerHTML = "Execute";
document.getElementById("input").appendChild(executeButton);
executeButton.onclick = execute;
} else {
document.getElementById("input").innerHTML = '<span
class="notsupported">' +
"Sorry, the WPS builder does not support the selected process."
"</span>";
// helper function to dynamically create a textarea for geometry (WKT) data
// input
function addWKTInput(input, previousSibling) {
alert("Hello! I am an alert box in dynamically create a textarea for
geometry data input!!");
var name = input.identifier;
var container = document.getElementById("input");
var label = document.createElement("label");
label["for"] = name;
label.title = input["abstract"];
label.innerHTML = name + " (select feature, then click field):";
previousSibling && previousSibling.nextSibling ?
container.insertBefore(label, previousSibling.nextSibling) :
container.appendChild(label);
var field = document.createElement("textarea");
field.onclick = function () {
alert("Hello! I am an alert box in onclick!!");
if (layer.selectedFeatures.length) {
alert("Hello! I am an alert box in selected features function for
geometry data input writing!!");
this.innerHTML = new OpenLayers.Format.WKT().write(
//layer.selectedFeatures[0]
//name.length();
//alert(trun.toFixed(2));
createCopy(input, this, addWKTInput);
field.onblur = function() {
input.data = field.value ? {
complexData: {
mimeType: "application/wkt",
value: this.value
} : undefined;
field.title = input["abstract"];
field.id = name;
container.insertBefore(field,
previousSibling.nextSibling.nextSibling) :
container.appendChild(field);
// helper function for xml input
function addXMLInput(input, type) {
var field = document.createElement("input");
field.value = name + " (" + type + ")";
complexData: {
mimeType: type,
value: this.value
} : undefined;
document.getElementById("input").appendChild(field);
// helper function to dynamically create a WFS collection reference input
function addWFSCollectionInput(input) {
field.value = name + " (layer on demo server)";
addValueHandlers(field, function() {
input.reference = field.value ? {
mimeType: "text/xml; subtype=wfs-collection/1.0",
href: "http://geoserver/wfs",
method: "POST",
body: {
wfs: {
version: "1.0.0",
outputFormat: "GML2",
featureType: field.value
} : undefined;
// helper function to dynamically create a raster (GeoTIFF) url input
function addRasterInput(input) {
var url = window.location.href.split("?")[0];
field.value = url.substr(0, url.lastIndexOf("/")+1) +
"data/tazdem.tiff";
(field.onblur = function() {
input.reference = {
mimeType: "image/tiff",
href: field.value,
method: "GET"
// helper function to dynamically create a bounding box input
function addBoundingBoxInput(input) {
field.value = "left,bottom,right,top (EPSG:4326)";
input.boundingBoxData = {
projection: "EPSG:4326",
bounds: OpenLayers.Bounds.fromString(field.value)
// helper function to create a literal input textfield or dropdown
function addLiteralInput(input, previousSibling) {
var anyValue = input.literalData.anyValue;
// anyValue means textfield, otherwise we create a dropdown
var field = document.createElement(anyValue ? "input" : "select");
field.id = name;
container.insertBefore(field, previousSibling.nextSibling) :
if (anyValue) {
var dataType = input.literalData.dataType;
field.value = name + (dataType ? " (" + dataType + ")" : "");
literalData: {
value: field.value
} : undefined;
createCopy(input, field, addLiteralInput);
} else {
var option;
option.innerHTML = name;
field.appendChild(option);
for (var v in input.literalData.allowedValues) {
option.value = v;
option.innerHTML = v;
field.onchange = function() {
input.data = this.selectedIndex ? {
literalData: {
value: this.options[this.selectedIndex].value
} : undefined;
// if maxOccurs is > 1, this will add a copy of the field
function createCopy(input, field, fn) {
if (input.maxOccurs && input.maxOccurs > 1 && !field.userSelected) {
// add another copy of the field - we don't check maxOccurs
field.userSelected = true;
var newInput = OpenLayers.Util.extend({}, input);
// we recognize copies by the occurrence property
newInput.occurrence = (input.occurrence || 0) + 1;
process.dataInputs.push(newInput);
fn(newInput, field);
// helper function for adding events to form fields
function addValueHandlers(field, onblur) {
field.onclick = function() {
if (!this.initialValue) {
this.initialValue = this.value;
this.value = "";
if (!this.value) {
this.value = this.initialValue;
delete this.initialValue;
onblur.apply(this, arguments);
// execute the process
function execute() {
var output = process.processOutputs[0];
var input;
// remove occurrences that the user has not filled out
for (var i=process.dataInputs.length-1; i>=0; --i) {
input = process.dataInputs[i];
if ((input.minOccurs === 0 || input.occurrence) && !input.data &&
!input.reference) {
OpenLayers.Util.removeItem(process.dataInputs, input);
process.responseForm = {
rawDataOutput: {
identifier: output.identifier
if (output.complexOutput &&
output.complexOutput.supported.formats["application/wkt"]) {
process.responseForm.rawDataOutput.mimeType = "application/wkt";
OpenLayers.Request.POST({
url: wps,
data: new OpenLayers.Format.WPSExecute().write(process),
success: showOutput
// add the process's output to the page
function showOutput(response) {
var result = document.getElementById("output");
result.innerHTML = "<h3>Output:</h3>";
var features;
var contentType = response.getResponseHeader("Content-Type");
if (contentType == "application/wkt") {
features = new OpenLayers.Format.WKT().read(response.responseText);
} else if (contentType == "text/xml; subtype=wfs-collection/1.0") {
features = new
OpenLayers.Format.WFST.v1_0_0().read(response.responseText);
if (features && (features instanceof OpenLayers.Feature.Vector ||
features.length)) {
layer.addFeatures(features);
result.innerHTML += "The result should also be visible on the map.";
result.innerHTML += "<textarea>" + response.responseText +
"</textarea>";
In this code
layer.selectedFeatures[0] i need to dispaly the values in that string
example like this POLYGON((77.34375 54.345677989,74.123434444
29.3452334,136.456 24.6789000)) here i need to first divide them into
individual values then turncate them
-----K.Manjula-------
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140522/e429514d/attachment-0001.html>
