[OpenLayers-Users] Need some help displaying a Vector layer
Martin Davis
mtnclimb at gmail.com
Tue Sep 30 09:22:10 PDT 2014
In montevideo.html:99 it looks like the code is using a Geometry as a
feature. It might be necessary to create a OpenLayers.Feature.Vector
containing the geometry, as in this example:
http://docs.openlayers.org/library/introduction.html#adding-a-vector-marker-to-the-map
On Mon, Sep 29, 2014 at 6:05 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi All,
> I'm a little rusty working in OL, I have a map and I'm trying to read some
> geometry from my server and display it as a vector layer. This is just a
> quick throw away map for diagnostic purposes.
> I have the data loading, and I can see it in firebug but I can not figure
> out why it is not displaying.
> http://imaptools.com:8080/demo/montevideo.html
> Load the page then click [Update Route] button to load the data ans
> display it (only it is not displaying).
> This should be loading some vectors in the bottom section of the map
> around the "B" in yellow.
> Yes, this is an old version, OL 2.10, but that should not matter as I'm
> doing the same sort of this on OL 2.9 and it was working there.
> I would appreciate if someone can give me a clue as to what my problem is,
> beside the obvious that I should start over with newer code :)
> Thanks,
> -Steve
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140930/fa8e89cf/attachment.html>
