[OpenLayers-Users] OpenLayers.Layer.XYZ - how to set origin?
Robert Sanson Robert.Sanson at asurequality.com
Wed Dec 30 12:05:00 PST 2015
Dear OpenLayers Users
I am trying to connect to a custom tile cache, using OpenLayers.Layer.XYZ
The projection used is EPSG:2193 (New Zealand Transverse Mercator) and the tileOrigin for this service is -1000000, 10000000 (top left)
The extents of the imagery are: [827933.23, 3729820.29, 3195373.59, 7039943.58]
How do I set the tileOrigin on the layer? Is it based on the map maxExtent?
Looking at XYZ.js it has:
     * Method: getXYZ
     * Calculates x, y and z for the given bounds.
     * Parameters:
     * bounds - {<OpenLayers.Bounds>}
     * Returns:
     * {Object} - an object with x, y and z properties.
    getXYZ: function(bounds) {
        var res = this.getServerResolution();
        var x = Math.round((bounds.left - this.maxExtent.left) /
            (res * this.tileSize.w));
        var y = Math.round((this.maxExtent.top - bounds.top) /
            (res * this.tileSize.h));
        var z = this.getServerZoom();
        if (this.wrapDateLine) {
            var limit = Math.pow(2, z);
            x = ((x % limit) + limit) % limit;
        return {'x': x, 'y': y, 'z': z};
    /* APIMethod: setMap
     * When the layer is added to a map, then we can fetch our origin
     *    (if we don't have one.)
     * Parameters:
     * map - {<OpenLayers.Map>}
    setMap: function(map) {
        OpenLayers.Layer.Grid.prototype.setMap.apply(this, arguments);
        if (!this.tileOrigin) {
            this.tileOrigin = new OpenLayers.LonLat(this.maxExtent.left,
                                                this.maxExtent.bottom);
Many thanks,
Robert Sanson
