[OpenLayers-Users] OpenLayers.Layer.XYZ - how to set origin?
Warren Vick wvick at europa.uk.com
Thu Dec 31 07:59:39 PST 2015
Hi Robert,
I've created tile services in a national projection (British National grid, EPSG:27700, in my case) and accessed them from OpenLayers 2. The extent (inc. origin) of your map is specified in "maxExtent" within the options (2nd parameter) of the map constructor. Your "resolutions" are also passed in there and allow for progressive scales other than x2. These two items of information are sufficient to frame your tile source. I also use TMS for tile layers, but that might have just been because XYZ was added later and I never bothered adopting it.
Regards,
Warren
-----Original Message-----
From: Users [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Robert Sanson
Sent: 30 December 2015 20:05
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] OpenLayers.Layer.XYZ - how to set origin?
Dear OpenLayers Users
I am trying to connect to a custom tile cache, using OpenLayers.Layer.XYZ
The projection used is EPSG:2193 (New Zealand Transverse Mercator) and the tileOrigin for this service is -1000000, 10000000 (top left)
The extents of the imagery are: [827933.23, 3729820.29, 3195373.59, 7039943.58]
How do I set the tileOrigin on the layer? Is it based on the map maxExtent?
Looking at XYZ.js it has:
     * Method: getXYZ
     * Calculates x, y and z for the given bounds.
     * Parameters:
     * bounds - {<OpenLayers.Bounds>}
     * Returns:
     * {Object} - an object with x, y and z properties.
    getXYZ: function(bounds) {
        var res = this.getServerResolution();
        var x = Math.round((bounds.left - this.maxExtent.left) /
            (res * this.tileSize.w));
        var y = Math.round((this.maxExtent.top - bounds.top) /
            (res * this.tileSize.h));
        var z = this.getServerZoom();
        if (this.wrapDateLine) {
            var limit = Math.pow(2, z);
            x = ((x % limit) + limit) % limit;
        return {'x': x, 'y': y, 'z': z};
    /* APIMethod: setMap
     * When the layer is added to a map, then we can fetch our origin
     *    (if we don't have one.)
     * Parameters:
     * map - {<OpenLayers.Map>}
    setMap: function(map) {
        OpenLayers.Layer.Grid.prototype.setMap.apply(this, arguments);
        if (!this.tileOrigin) {
            this.tileOrigin = new OpenLayers.LonLat(this.maxExtent.left,
                                                this.maxExtent.bottom);
Many thanks,
Robert Sanson
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
