[OpenLayers-Users] Confusion regarding shape file?
Maxime Demers
burton449geo at gmail.com
Sun Nov 15 15:13:09 PST 2015
Convert the shapefile into geojson maybe?
On 11/15/15, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> sukbir,
> geoserver is an option, mapserver and tinyows is another option. You
> will likely need to recreate your application using OpenLayers as gmaps
> is a closed proprietary library. If you are computing routes in gmaps,
> then you will need to look at pgrouting or some other routing solution.
> There is no simple answer to this question without knowing in detail all
> the typical transactions that are happening between your application and
> gmaps and know things like where do you store your data, etc.
> I would suggest loading the shapefile into postgresql along with any
> additional data you create like your geofences. Then these can be
> read/write/edited from things like geoserver or mapserver/tinyows.
> gmaps has some ability to pull data from other sources, but it is pretty
> limited and I'm pretty sure it does not support routing through other
> data. You might be able to put the data in postgresql and create an ajax
> handler to fetch limited amounts of data to put and work with in the
> client.
> Anyway this is just some ideas, other might have more ideas.
> -Steve
> On 11/15/2015 2:22 PM, sukbir singh wrote:
>> Dear Steve,
>> Yes currently we have written an application using
>> pure gmap where we can draw, save, edit and view geo fence using polygon
>> and polylines. Thereafter we can plot data and replay function all on
>> the gmap.
>> Now the issue is that I have a shapefile of particular country? How
>> can I load that shapefile?
>> My biggest challenge is how to port all the functionality done in google
>> map into this shapefile?
>> What I read so far is that I need to install a geoserver is that correct?
>> Yes my problem is now to render the shapefile as a map and secondly all
>> the functionality done via google map?
>> I hope I am clearer now?
>> > To: openlayers-users at lists.osgeo.org
>> > From: woodbri at swoodbridge.com
>> > Date: Sun, 15 Nov 2015 14:05:27 -0500
>> > Subject: Re: [OpenLayers-Users] Confusion regarding shape file?
>> > On 11/15/2015 1:36 PM, sukbir singh wrote:
>> > > Hi All,
>> > > Currently I have my application run well on google map. My
>> > > client now have a shape file for a specific country. He needs us to
>> run
>> > > the same functionality which we have in google map done on this
>> > > shapefile. So in order to run a shape file must I install e.g.
>> > > GeoServer. Then upon that I got to run open layers. How am I going to
>> > > integrate google map into open layers? Am I moving on the right path?
>> > > Thank you.
>> > I think you need to provide a little more information. From you
>> > description, it sounds like you have write an application based on gmap
>> > api. Now you have a shapefile,
>> > what do you want to do with that?
>> > * edit the shapefile data?
>> > * display it as a base map?
>> > * do you need vectors from the shapefile to manipulate?
>> > * or just to render the shapefile as a map?
>> > * etc
>> > Without know what your app does and what you want to do with the
>> > shapefile data, it is hard to make recommendations.
>> > -Steve
>> > _______________________________________________
>> > Users mailing list
>> > Users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Stack Overflow: http://stackoverflow.com/users/1914034/burton449
GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
LastFm: http://www.lastfm.fr/user/burton449
