[osgeo4w-dev] osgeo4w-setup: what does "up to date" mean?
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Apr 18 12:44:46 EDT 2008
> I *think* the View "up to date" will show you a list of all packages
> believed to be up to date according to the current criteria.
> The current criteria is determined by the radio buttons along the top.
> If you want to upgrade to the newest trusted version you would set this
> to "Curr" (current) which I believe is the default. In this case I think
> all packages should be upgraded if practical. Perhaps you had it set in
> "Keep" mode?
No, I left it at default, which is Current. With the Category view set
to "Up to date", changing the radio position has no apparent effect on
the package selection. With Category Full, there is sometimes a flicker
when changing radio position, but no version numbers change that I can
see (there are about a dozen unseen packages off the bottom).
So right now I have gdal 1.5.0-3 installed. Clicking in the New column
shows 1.5.1.1 is available. Should 1.5.1 be in the Current or
Experimental category? Either way, something appears to be not working,
as I would expect it to show up without drilling down for it.
Looking at http://cygwin.com/setup.html and the setup.ini for
osgeo4w-setup I don't see the following three keywords used from setup.hint:
curr: version
prev: version
test: version
I tried manually editing setup.ini (gdal section below) and adding them,
then running osgeo4w-setup and installing from local directory, but it
didn't change anything. Perhaps the format of those for setup.ini is
different from setup.hint?
@ gdal
sdesc: "The GDAL/OGR library and commandline tools"
ldesc: "The GDAL/OGR library and commandline tools"
category: Libs Commandline_Utilities
requires: msvcrt tiff libjpeg libgeotiff proj hdf5 curl geos libmysql
sqlite3 netcdf libpq expat xerces-c hdf4 ogdi
version: 1.5.1-1
curr: 1.5.0-3
prev: 1.5.0-2
test: 1.5.1-1
install: ./release/gdal/gdal-1.5.1-1.tar.bz2 2138013
f3eda2f2799735c60824d8f31f77e410
source: ./release/gdal/gdal-1.5.1-1-src.tar.bz2 5425
fe057edbb6a4dd1271896a79bb840a75
[prev]
version: 1.5.0-3
install: ./release/gdal/gdal-1.5.0-3.tar.bz2 2136700
4333351cce00ef77eaf6548a8f444e31
source: ./release/gdal/gdal-1.5.0-3-src.tar.bz2 5826
ff1f54d2573eabd4ff48fe1fabd708ac
I just noticed something else: version 1.5.0-3 is listed under the
[prev] heading, yet it is the default package for the Current radio
button. I didn't edit that part.
> Indeed, some of these may be quirks where we aren't seeing the intention.
> I'm hesitant to fiddle much with such core behaviors.
Agreed, for the dependency-resetting behaviour.
-matt
More information about the osgeo4w-dev
