[osgeo4w-dev] Updates
Frank Warmerdam
warmerdam at pobox.com
Sat Apr 26 17:37:19 EDT 2008
Folks,
In the least few days, I've done a few updates.
1) Updated msvcrt (base) packaged to include a o4w-env.bat script which
other scripts can source to setup the environment. This doesn't matter
for commandline programs run from the shell, but it does matter for stuff
run from icons.
2) Updated textreplace in msvcrt so that "-t abc.txt" will update abc.txt
in place if there is no abc.txt.tmpl file. As Jeff has pointed out it
is preferrable to update stuff in place rather than have template files
so that uninstall will cleanup better.
3) Added a menu item and a desktop icon for the OpenEV package.
4) Packaged Java MapScript (as mapscript-java). I'm not too clear yet
how we are going to make these .jar files be in the "standard classpath"
or even if that is desirable.
5) Updated the setup program to include an OpenEV item in the express
install.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the osgeo4w-dev
