[osgeo4w-dev] setup in svn and improved a bit
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 29 11:58:51 EST 2008
Jason Fournier wrote:
> Hi Frank,
> I've downloaded and executed osgeo4w_setup.exe. I opted to install
> everything in the list. The installation went smoothly and was intuitive.
> Once complete I opened the OSGeo shell and attempted to run shpproj.exe. I
> received the following message:
> C:\OSGeo4W>shpproj
> The system cannot execute the specified program.
> I have verified that OSGeo4W\bin is in my PATH. If I navigate to the bin
> dir I receive the same message:
> C:\OSGeo4W\bin>shpproj
> Prior to installation I performed a search for MSVCR90.DLL and could not
> find a copy (although I'm not entirely confident about Windows' search
> capabilities).
> Let me know if there's anything else I can do.
Jay,
Thanks! It seems like I still have work to do with regard to manifests
and VS8/9. Could you just do a quick check in your C:\OSGeo4W\bin
directory and check for the MSVCR90.DLL there? It was supposed to get
installed as part of msvcrt-1.0.0-3. Perhaps I forgot to regenerate
the setup.ini file.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the osgeo4w-dev
