[osgeo4w-dev] So does this mean the old non-networked versions
will die?
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Jun 25 12:40:00 EDT 2008
Hi Jo,
I haven't heard any noises about FWTools and friends being discontinued,
but even if they are one can still install osgeo4w without being
networked, though you do need the network at least once.
Acquiring the packages:
* Run osgeo4w-setup, select Advanced Install, then "Download without
installing", then the rest of the prompts as you like.
* Copy osgeo4w-seup.exe and the local cached package directory to
cdrom, usb key or whatever
Install on disconnected machine:
* Run osgeo4w-setup, select Advanced Install, then "Install from
local directory", and continue as though wilt.
This procedure is also useful in network situations where you have a
bunch of workstations to install to and want to limit external bandwith,
just plunk the package cache on a network share.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Joanne Cook wrote:
> Hi all,
> I am just wondering what this means for the old way of acquiring
> FWTools et al. I am interested in providing GIS in environments where
> a network connection is not always a given- such as disaster
> response, or just places where the phone signal is a bit rubbish (the
> Welsh Mountains or the Lake District in the UK for example). Will
> FWTools et al still exist in their current format? Or do I have to
> figure out how to make OSGeoFW work portably? :-)
> All the best
> Jo
> ----------------------------------------------------- Joanne Cook
> Senior IT Support and Development Oxford Archaeology (North) 01524
> 880212 http://thehumanjourney.net
> ------ Files attached to this email may be in ISO 26300 format (OASIS
> Open Document Format). If you have difficulty opening them, please
> visit http://iso26300.info for more information.
> _______________________________________________ osgeo4w-dev mailing
> list osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
