[osgeo4w-dev] Progress Update
    andrea antonello
    andrea.antonello at gmail.com
    Fri Mar 14 18:53:07 EDT 2008
Were are applications supposed to live, that are completely contained
inside a folder and are not flexible enough to be split into bin, lib
and share etc? Udig is an executable inside a folder containing all
the needed libs and referring to those through the internal relative
path. I will investigate the possibility to split, but were to put it
if it has to be like that? Perhaps a /opt would be the most linux-like
choice? Are there other softwares having the same porblem?
Thanks,
Andrea
On Wed, Mar 12, 2008 at 12:51 AM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> andrea antonello wrote:
>  > Through a quick search I couldn't find the cygwin installer engine and
>  > docs about how to package software through it. Could someone kindly
>  > provide me with a link?
>  Andrea,
>  http://wiki.osgeo.org/wiki/OSGeo4W_Packaging
>  I'll try and make this more prominent on the OSGeo4W page.  Currently
>  it is buried pretty deep.
>  > PS: together with the udig community we will try to package uDig.
>  Sweet!  I'm interested in how the Java runtime environment will be
>  handled.  Will you try to use the system Java?  Or provide your own
>  that just sits in the OSGeo4W tree?  Will you try and install the
>  OSGeo4W Java in such a way that it becomes available as the system
>  Java environment?
>  I'd be pleased to lend a hand and answer questions where I can.  I'm
>  also interested in getting Java MapScript and GDAL/OGR Java bindings
>  working once you have the basic Java runtime rules worked out.
>  Best regards,
>  I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>  light and sound - activate the windows | http://pobox.com/~warmerdam
>  and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the osgeo4w-dev
