[osgeo4w-dev] Grass packager?
Frank Warmerdam
warmerdam at pobox.com
Tue Mar 18 19:19:25 EDT 2008
andrea antonello wrote:
> from a user that tried the installer:
> Express Install does not work; checking GDAL and pressing NEXT produces
> a bunch of warnings about "Un met Dependencies Found" (for curl, expat,
> geos, hdf4 etc...). Pressing BACK from the Express Install takes you to
> the same broken Select Packages screen.
Andrea,
I'll dig into this. I may need to strip a system down a bit.
And I have no idea about the dos box / start issue. Hopefully someone
else has a suggestion.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the osgeo4w-dev
