[osgeo4w-dev] Re: [OSGeo] #235: Remove dll and exe version numbers
from MapServer and PHPMapscript dev packages
OSGeo
trac_osgeo at osgeo.org
Fri Mar 21 17:16:48 EDT 2008
#235: Remove dll and exe version numbers from MapServer and PHPMapscript dev
packages
Reporter: jmckenna | Owner: osgeo4w-dev at lists.osgeo.org
Type: task | Status: closed
Priority: normal | Component: OSGeo4W
Resolution: fixed | Keywords:
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
I have repackaged these to use the new conventions.
I also enabled WCS 1.1 by adding -DUSE_LIBXML2 to the nmake.opt file. I'll
need to make building this way easier in trunk.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/235#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the osgeo4w-dev
