[osgeo4w-dev] GeoServer in OSGeo4W
andrea antonello
andrea.antonello at gmail.com
Thu Mar 27 16:45:55 EDT 2008
Hi Mike,
if you have questions about the udig and java setup, just drop me a note.
I didn't yet repackage udig, but apart of no more putting java under
desktop category, the install should be as it is now. Let me know if
it is ok for you, else we can change it together. It really should be
the same java. Geoserver is on 1.6 or 1.5? I am loading a 1.6, but if
really necessary we could go by 1.5.
Ciao
Andrea
On Thu, Mar 27, 2008 at 9:33 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Mike Pumphrey wrote:
> > Hello everyone. My name is Mike Pumphrey and I'm the Outreach Engineer
> > for GeoServer at The Open Planning Project. I'm interested in learning
> > about the process of integrating GeoServer with the OSGeo4W project. I
> > am not quite sure which questions to ask at this point, but if someone
> > could point me in a direction (or two), that would be very appreciated.
> Mike,
> I would suggest you read over:
> http://wiki.osgeo.org/wiki/OSGeo4W_Packaging
> And of course the general information at:
> Then I would suggest you install stuff (use advanced, not express)
> including uDig. Then review how udig is setup. You can download the
> udig .tar.bz2 file itself, and review its contents with some care to
> see exactly what they provided. I imagine it will provide a model for
> GeoServer.
> Presumably (hopefully!) you can use the same Java environment as udig.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
