[osgeo4w-dev] gdal-python packages & gdal_merge
Fri Oct 10 08:16:21 EDT 2008
fabienne picot wrote:
> Is the command:
> C:\OSGeo4W>gdalinfo  ??
> Because this one doesn't work. But I just begin with the command line,
> and I don't know really the correct synthaxe.
Fabienne,
I was thinking of just typing "gdalinfo" at the commandline.   You
should get a usage message something like:
Usage: gdalinfo [--help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
                 [-noct] [-checksum] [-mdd domain]* datasetname
Best regards,
More information about the osgeo4w-dev mailing list
