[osgeo4w-dev] gdal-python packages & gdal_merge
Matt Wilkie
matt.wilkie at gov.yk.ca
Fri Oct 10 14:57:24 EDT 2008
> But in the worst case you would end up having to switch things back
> and forth depending on your use.
> I would note that OSGeo4W deliberately does not copy anything to
> c:\windows\system32 in order to avoid breaking other applications.
> I only wish other applications were so careful.
One might try removing C:\Windows and C:\Windows\system32 from path
within the osgeo shell. Edit c:\osgeo4w\osgeo4w.bat and delete %PATH%
from the line:
PATH=%OSGEO4W_ROOT%\bin;%PATH%
When I do that on my computer gdal_merge still works.
Standard programs like xcopy become unavailable though.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
More information about the osgeo4w-dev
