[osgeo4w-dev] packaging a tad bumpy
Jürgen E. Fischer
jef at norbit.de
Mon Apr 6 04:36:25 EDT 2009
Hi Matt,
On Mon, 06. Apr 2009 at 01:07:16 -0700, Matt Wilkie wrote:
> I encountered a number of packaging difficulties with the trivial mys
> change (#78) unrelated to the change itself. I'll share them here in
> the hopes we might find a way to smooth some of them out.
> * http://upload.osgeo.org/cgi-bin/osgeo4w-regen.sh did not update
> either setup_test.ini or versions*.html pages. It took about a minute
> to run.
I didn't have that setup_test.ini problem yet.
> * running regen.sh from login shell updated setup_test.ini but not
> the versions*.html pages
And the versions*.html pages are generated by cron (I think Markus
Neteler did that). So that's normal.
> A few weeks ago I reported that setup.exe cannot unpack the tar.bz2
> created by 7zip. Today I can extend that lack of success to also
> include gnuwin32's bzip2. Surprisingly I'm pretty sure cygwin's own
> bzip2 also doesn't work though I didn't test this last on completely
> because I was tired of up/dnloading the same file over and over again.
> When I diff'd gnuwin32 and cygwin's output, the files were exactly the
> same.
Hm, I create my .tar.bz2 on Linux - although I would not have expected
problem in Windows. Did you compare the Linux and Windows version? And
might the regen problem also relate to the "broken" packages?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
