[osgeo4w-dev] packaging a tad bumpy
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Apr 7 19:22:29 EDT 2009
> Hm, I create my .tar.bz2 on Linux - although I would not have
> expected problem in Windows. Did you compare the Linux and Windows
> version?
diff says the "the files differ", while ls says the 7z-created .bz2 is
~550k smaller:
/home/maphew/bug-7z-no-good-for-setup$ ls -l
total 5000
-rw-rw-r-- 1 maphew maphew 2554936 Apr 6 00:23 msys-1.0.11-3.tar.bz2
-rw-rw-r-- 1 maphew maphew 2554373 Apr 7 14:57 msys_7z.tar.bz2
Linux tar & bzip have no problem extracting the 7zip tar.bz2.
> And might the regen problem also relate to the "broken" packages?
I hadn't thought of that. I don't know enough about perl or the genini
script to test further. The packages quoted above are in my home
directory if anyone wants to dig further.
best regards,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
More information about the osgeo4w-dev
