[osgeo4w-dev] Re: [osgeo4w] #83: grass pkg: terminal not available
 until you exit the gui
    trac_osgeo4w at osgeo.org
    Thu Aug 27 08:46:11 EDT 2009
#83: grass pkg: terminal not available until you exit the gui
Reporter:  hamish  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |       Status:  new
Priority:  major   |    Component:  Package
 Version:          |   Resolution:
Keywords:  grass   |
Comment (by dvictori):
 Just installed Grass6.4 svn3 (from osgeo4w) and I can't get access to the
 DOS terminal when I run Grass wxpython. So I don't know if the ticket does
 not apply to wxpython as Jeff says
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/83#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
