[osgeo4w-dev] Re: [osgeo4w] #83: grass pkg: terminal not available
until you exit the gui
trac_osgeo4w at osgeo.org
Thu Aug 27 10:09:19 EDT 2009
#83: grass pkg: terminal not available until you exit the gui
Reporter: hamish | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: grass |
Comment (by hamish):
Replying to [comment:5 dvictori]:
> Just installed Grass6.4 svn3 (from osgeo4w) and I can't get
> access to the DOS terminal when I run Grass wxpython. So I
> don't know if the ticket does not apply to wxpython as Jeff says
dumb question: do you start Grass wxpython using the Start Menu + version
which says +DOS prompt, or just by double clicking on the
desktop icon? (which doesn't give you a dos box)
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/83#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev
