[osgeo4w-dev] Re: [osgeo4w] #83: grass pkg: terminal not available until you exit the gui
OSGeo4W trac_osgeo4w at osgeo.org
Thu Aug 27 10:46:49 EDT 2009
Reporter:  hamish  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |       Status:  new
Priority:  major   |    Component:  Package
 Version:          |   Resolution:
Keywords:  grass   |
Comment (by dvictori):
 I'm starting Grass from the desktop icon (Grass GIS wxpython) which
 does open a dos prompt but I can't use it. If I go through the start
 menu (start / osgeo4w / grass gis / wxgui) I get the same results, an
 open but unresponsive DOS prompt.
 I don't see any option on the OsGeo4W menu that says Grass+DOS prompt
 I'm using WinXP and the OsGeo4W installer says I got grass version
 6.4.0svn3.
 Daniel
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/83#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
